Should I buy a watch winder ?
Yesyesnono
Post by Yesyesnono » Tue Jan 14, 2020 8:30 pm
Hello all
I have a few automatics now and started to find I need to wind the watches quite often I do fancy a watch winder they seem to have a bit of bad press but any comments be gratefully received
Re: Should I buy a watch winder ?
Post by scooter » Tue Jan 14, 2020 8:41 pm
There have been many threads on this topic both here and on just about every watch Forum.
The final result usually ends up a draw.
Personally, I used one for many years but when it broke I didn't buy another.
Yesyesnono
Post by Yesyesnono » Tue Jan 14, 2020 9:24 pm
Super thanks
Lawrence
Post by Lawrence » Tue Jan 14, 2020 9:37 pm
I've reached a compromise with myself.
I have several watch winder but leave them unplugged.
Bulova Accutron Gemini
C60 Trident Bronze Pro 600
C60 Trident Blue Pro 600
C65 Trident Bronze SH21 LE
C65 Trident Black
Tudor Black Bay Heritage Maroon
Tudor Black Bay Heritage Black
Post by Amor Vincit Omnia » Tue Jan 14, 2020 9:41 pm
Yes.
No.
Yes.
No.
Depends.
If you have an automatic with a date that you wear, say, two or three times a week they can be useful. My Cartier Tank lives on one quite a lot of the time.
Post by Thegreyman » Tue Jan 14, 2020 9:58 pm
I currently have 12 autos and have never bothered with a winder. I personally don’t see the need unless maybe you had only 3 or 4 watches you wore regularly in which case say a 2 watch winder might be more justified. With the number I have (and plenty of folk on here have more watches than me) I’d need a bank of them.
Post by downer » Tue Jan 14, 2020 10:11 pm
I had 12 running at one time, but these days I only have a single winder running.
Overall, I think they are a good thing, but a nice-to-have rather than a necessity.
Post by Lavaine » Wed Jan 15, 2020 4:38 am
I don't own one, and personally only two good use cases for having one.
1. You only wear 2-3 watches in a daily rotation. In this case having one might make sense rather than winding and setting each of your watches multiple times per week.
2. You own a very complicated watch, such as a perpetual calendar. Having to set a perpetual calendar each time you wear it defeats the purpose.
So my answer is maybe, but not likely.
Post by H0rati0 » Wed Jan 15, 2020 11:01 am
Wot he said - my reasons in a nutshell for running a 4 hole winder and I do find it worthwhile (just) as a nice to have.
NB, watches that run slow need to be reset once in a while (I keep a radio controlled Casio on the bedside table for reference) while watches that run fast are more convenient, just require a few seconds interruption once out of the winder.
Moonphase/calenders etc. are a real pain unless on a winder and so end up not being worn as often as they should.
Post by stefs » Wed Jan 15, 2020 11:23 am
I have a 4 watch winder which is now one too few! Personally I think they are handy as long as they do what your watches need in terms of direction and numbers of turns. My watches all maintain time really well using it. I like them but from what I have read some watchmakers do not!
Cheers now
Paul
rolex explorer 214270,explorer ii 16570,JLC reverso duo 2718410,Longines LD 36,Oris bcpc bronze,Seiko5 sports,RW parsifal
Post by Viognier » Wed Jan 15, 2020 3:42 pm
I have a dual winder, it's convenient to grab and go on those automatic movement watches.
DavecUK
Post by DavecUK » Wed Jan 15, 2020 5:23 pm
I have one dual; winder. I have only a need to ever keep 2 automatics wound, the others I am happy to let run down and rest when I'm not planning on wearing them for a while..usually the winders only got 1 watch in it at most as the one I am wearing doesn't need to go into the winder at night. I simply take it off and leave it on the night stand.
I also tend to switch the winder off for a day or two once an SH21 is fully wound. My winder is a cheapie only cost about £25 rotates both ways periodically, but I can't set it for number of turns every day or anything like that.
CW-watches: 21
Post by MiniMpi » Wed Jan 15, 2020 8:05 pm
I have a nice one that I won from the forum for a competition a few years ago but to be honest it gets no use at all.
However I may put two watches I use for work into it purely because I am running out of space in my watch boxes and as I get up at 04:15 twice a week it's handy to have the two automatics set and ready to go.
C65 SH21 LE #070/150, C9 AM GT LE #001, C60 Ombré #001, C1-GM-5DA, C9-JH-MK3, C7 Proto, C11 Elite, C7 Bluebird, C70 Ascari, C70 HRDC, C7 COSC LE, C65 Diver, C65 MK1 LE, C60 MK3, C60 316L LE, C60 GMT MK2, C60-TI-V2, C8 UTC, C8 MK2, C600-IPB, C5 MK3.
Post by nbg » Wed Jan 15, 2020 8:15 pm
I have a couple of winders. Haven’t used them for a few years.
I tend to pick three main watches to wear over a week or so, before switching to another three. Always found it easy enough to keep all three running without the need for winders.
I probably wear another three or four at some point during the week, which I just pick from the box and set for the few hours that they are likely to be worn. A couple of winders wouldn’t really help, as I have no idea what other watches I am likely to pick before I choose them.
0uatiOW
Post by 0uatiOW » Wed Jan 15, 2020 9:42 pm
I use winders. The conclusion when this topic has been discussed before tends to be that it’s a matter of choice and convenience. I like the convenience of a watch being more or less correct when I put it on.
I recently took a trip with 3 watches and I rotated religiously each day, but the constant need to correct and wind every day reminded me why I like a winder. OK, a first world problem, but still....
If you have several watches and tend to wear a different one each day, then a winder is very convenient, but the ‘need’ in terms of mechanical benefit hasn’t been confirmed. Indeed, some folks says the additional wear is a bad thing.
