Strap Width Questions
shef175
Post by shef175 » Sun Jan 12, 2020 2:39 am
Hey all...just ordered my first CW during the January sale, a 38mm C60 Trident Bronze Pro 600, and I'm super excited about it. My question relates to strap changes. I ordered with the hybrid strap but I would like to order some other straps, either from CW or another company. Since my model has a 20mm lug width, could I make a 22mm strap still fit, depending on the strap material (NATO or raw edge leather)? Would a 22mm strap look too big on that size of case?
Lastly, any recommendations for straps with a bronze clasp?
Thanks in advance!
EddieTheBeast
Re: Strap Width Questions
Post by EddieTheBeast » Sun Jan 12, 2020 8:12 am
Welcome to the forum and congratulations on picking up your first CW! I was in the same position picking up my first CW watch, also a C60, in the December sale 3 years ago - and then joining the forum!
I think 22mm straps will be awkward to make fit and will look a little bit big for the 38mm C60. Your best bet would be to stick with 20mm straps. Try www.cheapestnatostraps.com
Dean
shef175
Post by shef175 » Sun Jan 12, 2020 8:25 am
Thanks for the response! I've seen people on other sites talking about it with other watches, but they might have bigger cases so the 22mm matches a bit better. I'll just wait until it gets here to see how it fits and looks in person before I pull the trigger on another strap.
Post by Amor Vincit Omnia » Sun Jan 12, 2020 8:32 am
Hello and welcome. Whilst a wider strap might not look as bad as one that is too narrow, I would be a bit concerned that it might inhibit the spring bars from sitting properly. I've seen people shave the lug end of a strap but it doesn't look right. Stick with 20mm.
shef175
Post by shef175 » Sun Jan 12, 2020 8:36 am
Cool, I'll just stick with 20mm. Also just realized there is a whole forum devoted to straps. I could have posted in there had I opened my eyes first...lol
CW-watches: 28
Post by Bahnstormer_vRS » Sun Jan 12, 2020 8:44 am
shef175 wrote:Cool, I'll just stick with 20mm. Also just realized there is a whole forum devoted to straps. I could have posted in there had I opened my eyes first...lol
Welcome to the forum and don't worry about posting in the wrong forum, topics can be moved by the Admin Team; as this one has been.
As to your question, in essence, stick with 20mm straps but if you use NATOs larger ones i.e. 22mm will fit for a different look.
Also, have a look around the Straps forum any you'll find plenty of suggestions for where to buy.
Good luck.
StrappedUp
Post by StrappedUp » Sun Jan 12, 2020 9:57 am
If you're looking for a strap that looks a bit wider, search for one that is flared at the lugs.
Something like this WatchGecko rubber ...
shef175
Post by shef175 » Sun Jan 12, 2020 11:09 am
Thanks for letting me know about that site. Not buying that rubber strap but I found a couple of NATOs on there that I might end up buying in the future
Post by H0rati0 » Sun Jan 12, 2020 3:47 pm
I'd echo the advice above and say stick to 20mm - it's the perfect size. You have abundant choice so why muck about?
Post by Viognier » Mon Jan 13, 2020 5:06 pm
20mm size for certain !!
Try CW straps as their options include a bronze buckle on an additional pin and buckle strap purchase.
Also be mindful of the taper from the lugs to the buckle (often straps taper from 20mm lugs to 18mm at buckle. You will see this noted as 20/18). When sourcing an aftermarket strap, with the identical taper to your OEM strap, you can switch the existing bronze CW buckle over to your aftermarket.
Other quality options popular here:
  • Hirsch
    Martu
    Mansrea
    Barton
    Steveo
    Aaron Bespoke
    Footycrazy (a forum member)
shef175
Post by shef175 » Tue Jan 14, 2020 1:00 pm
That's a good idea to switch the existing bronze CW buckle to the aftermarket strap...I hadn't considered that. Thanks!
CW-watches: 28
Post by Bahnstormer_vRS » Tue Jan 14, 2020 4:36 pm
shef175 wrote:That's a good idea to switch the existing bronze CW buckle to the aftermarket strap...I hadn't considered that. Thanks!
Be careful.
Once you get into the swing of things, it becomes addictive.
