If you choose to request a specific serial number when reserving a C600 be advised that you will not be able to specify a color. This is due to the way CWL serials are assigned at production.
You can proceed to order online, before check-out you will get to special delivery instructions….
Put in this box “ serial number request #10 or whatever you want”
HOWEVER…… because of the seal on this watch, it is not possible for CWL to swap backplates to fit the right color dial.They are not in a position to specify random serial numbers to the factory to produce as per serial number requests, this would take too long for production.
They will do their very best to fulfill all requests for serial numbers on the C600…..but cannot guarantee a color.
C600 serial numbers
C600 serial numbers
- 15 Replies
- 531 Views
Last post by Jameswombleporter
- 409 Views
