Private messages
redmonaco
Private messages
Post by redmonaco »
I don't seem to be able to delete my rather full inbox. When I select and the delete it tells me that there is a form submission error...
Any help gratefully received
CW-watches: 146
Re: Private messages
It is a technical glitch that we are trying to get rectified.
The current limit for your inbox is currently at 1600. If you need more than that I can raise it. Of course this is only a temporary solution, but it will keep communications open.
welshlad
Post by welshlad »
You can still delete messages one by one, by opening the message in question and then clicking on the box with an X in it for deletion.
It's the batch process for deleting several messages that doesn't work at the moment.
CWL C3 Mk1 | C60 Mk2 CWE | C60 Mk3 Ombre | C65 SH21 | C70 x4 | C8 | C15
Citizen Promaster Tissot V8 Vratislavia S6 Luch 1Hand
redmonaco
Post by redmonaco »
Thanks for your replies :0)
