To Repair or Not
Foxman50
To Repair or Not
Post by Foxman50 »
So i have purchased one of these, 2nd hand obviously but as new condition, still had all stickers on.
I have to say its one of those watches that images do not do justice, i think it’s by far the best looking watch i have, though limited collection.
Anyway i have noticed that the lower hour hand does not stop even though the second and minute hands do, the reset works fine but the hour will then start to count. Is this an annoyance, not really but think I’d prefer it to be static which I’m guessing it should be right.
Should the seller have informed me, yes, am i glad he didn’t, yes, as it may have deterred me from the purchase. It still has 4 years CW warranty so no rush to do anything about it, but as it’s in mint condition im concerned about returning it for repair in case it gets marked.
What are the forums thoughts, suppose this is more to do with the quality of CW’s service.
On another note, if i leave it as is will it have any wear implications on the mechanicals or reduce the power reserve.
Advice would be appreciated.
Zax
Re: To Repair or Not
Post by Zax »
I would take advantage of their warranty if I were you. You could always wear it til it needs servicing and have it fixed then too.
tikkathree
Post by tikkathree »
This is a 7750 movement watch isn't it?
I'd get it settled whilst well within warranty. For me a chronograph function which is unreliable is no good at all.
C60 MKII Day Date LE, GMT White, LE SH21 x2, ACAN, Bronze Ombre LE,
C6 K'fisher x6,
C60 K'fisher x3
C600 Tritech x 3,
C63 Elite
C65 Anthropocene. Blue h/w,
tikkathree wrote: Sat Aug 01, 2020 2:36 pm This is a 7750 movement watch isn't it?
Correct!
Here’s the CW Archive reference.
I would say definitely get it sorted.
Linguistic sophist; (nearly ex-) teacher; pilgrim; wannabe travel writer
Walk a while in others' shoes...
Foxman50
Post by Foxman50 »
Thanks for the comments, has anyone had a bad experience with CW service as in damage
Foxman50 wrote: Sat Aug 01, 2020 3:48 pm Thanks for the comments, has anyone had a bad experience with CW service as in damage
I’ve had a couple of good ones. The watch developed a fault, I sent it back, it came back sorted.
brash47
Post by brash47 »
Just take good detailed photos before you send it and then make a comparison when you get it back.
You can always send the photos with the repair order so it's documented the condition its in. If it's different afterwards, then you should completely expect them to make it right.
Brash
Sent from my SM-G988U using Tapatalk
CW-watches: 25
I've had quite a few watches go into CW for service / repair / battery change over the years. All have had the work completed satisfactorily and the watches returned in good condition.
To give a balanced viewpoint, I have read occasional reports on here of minor issues, which CW with good grace have rectified.
If you do a search on the Interweb, you will be able to find reports of issues with other manufacturers, including the likes of Rolex and Omega.
We are all human and mistakes happen.
C8 Reg LE| C8 M2.04 LE| C8 Al Deere| C9 FLE| C9 Me109 SPC LE| C11 Mak Navy| C40
C60 FLEx2| C60 Bronze-316L| C60 Apex-Elite P'type-AbyssSH21-Chrono |C65 Chrono-AM GT 2VEV
Foxman50
Post by Foxman50 »
brash47 wrote: Sat Aug 01, 2020 6:53 pm Just take good detailed photos before you send it and then make a comparison when you get it back.
Brash
That’s a great idea, obvious but hadn’t thought of it. Cheers
Foxman50
Post by Foxman50 »
Bahnstormer_vRS wrote: Sat Aug 01, 2020 7:15 pm If you do a search on the Interweb, you will be able to find reports of issues with other manufacturers, including the likes of Rolex and Omega.
That’s why i’m reluctant to send it, it can get lost in transit, damaged in transit, damaged at CW. It is no longer available, though maybe they have spares should it go wrong. Maybe i worry to much.
Foxman50 wrote: Sat Aug 01, 2020 7:24 pm Maybe i worry to much.
Maybe I’m just a little ray of sunshine. I’m sure we could have a fascinating philosophical discussion over a pint sometime.
Oh, and when I had drunk half of it my glass would definitely be half full.
Foxman50
Post by Foxman50 »
Amor Vincit Omnia wrote: Sat Aug 01, 2020 7:39 pm Oh, and when I had drunk half of it my glass would definitely be half full.
If your buying i’d expect mine to be topped up :thumbup:
CW-watches: 25
You could get run over by a bus crossing the road. :problem:
Foxman50
Post by Foxman50 »
Bahnstormer_vRS wrote: Sat Aug 01, 2020 7:42 pm You could get run over by a bus crossing the road. :problem:
Now that’s just silly, when do you see buses crossing the road :D
Foxman50
Post by Foxman50 »
Ok ok i think i get the point, will send it once their service is open again. Thanks all
