C65 automatic steel bracelet - not quick release?
Re: C65 automatic steel bracelet - not quick release?
Post by H0rati0 » Fri Feb 21, 2020 8:13 pm
Bellefield wrote:
Fri Feb 21, 2020 5:21 pm
Good idea, I might give that a go, although your pins have ledges that mine don't, I ended up using my pointy tweezers to grip them and pull down which worked well but I couldn't get the other end out, maybe due to the additional pressure due to the loose end of the spring being compressed against the case rather than in the hole.
When you do get them out, make sure to change the springbars, see the following.
viewtopic.php?f=53&t=50289
Bellefield
Post by Bellefield » Mon Feb 24, 2020 7:03 pm
Wow, thanks for that, glad I'm not the only one. Update: replacement spring bars are ordered, as is that nifty tool! :D
Bellefield
Post by Bellefield » Mon Mar 09, 2020 2:47 pm
thought I'd better give an update on this. CW have been amazing and have sent out a replacement bracelet with the QR bars. Took about 5 minutes to remove a link from either side and then fit to my watch, no problems. I really like the leather strap that I bought with it but I think I'm going to stick with the bracelet for a while at least as it fits and sits a lot better than the strap, as I find myself fiddling with the sizing on the strap, but the bracelet is now set up to fit just right.
CW-watches: 21
Post by MiniMpi » Mon Mar 09, 2020 4:56 pm
Brilliant news !
Thank you for the update, glad to see you got sorted.
C65 SH21 LE #070/150, C9 AM GT LE #001, C60 Ombré #001, C1-GM-5DA, C9-JH-MK3, C7 Proto, C11 Elite, C7 Bluebird, C70 Ascari, C70 HRDC, C7 COSC LE, C65 Diver, C65 MK1 LE, C60 MK3, C60 316L LE, C60 GMT MK2, C60-TI-V2, C8 UTC, C8 MK2, C600-IPB, C5 MK3.
