C60 Crown "cracking"
ondris
Post by ondris » Mon Feb 17, 2020 9:13 am
Hi,
I am owner of a C60 Bronze, that looks and feels fantastic!
But I just noticed today, after setting the time, that when I screw down the crown, it makes a sort of cracking/grinding noise.
I don't remember that the sound was present when I first got the watch out of the box.
First I thought there was dust in the thread, but It sounds more like a spring.
Also, it is not as repetitive as the cliks from the Bezel for example.
The "cracks" are quite uneven.
Should I be worried of something?
Paul Drawmer
Re: C60 Crown "cracking"
Post by Paul Drawmer » Mon Feb 17, 2020 10:26 am
Well, it's not right, as the normal action is completely smooth. From your desciption, either there's grit in there or the crown release spring is caught up on something.
Send it in to CW - give them a ring to ask them what to do.
ondris
Post by ondris » Mon Feb 17, 2020 10:28 am
Thank you Paul.
I have sent an e-mail to CW to see what they think about this.
Post by Amor Vincit Omnia » Mon Feb 17, 2020 10:42 am
I'm pretty sure Paul is right, but I'd suggest one thing...
It's a bit difficult to explain, but when screwing down a crown I always turn it (slowly) anticlockwise, while pushing the crown gently in towards the case. When I feel a click, which I guess is the thread seating itself properly, then I roll it clockwise and it always screws down smoothly. Some crowns can be little sods for getting cross-threaded.
ondris
Post by ondris » Mon Feb 17, 2020 10:47 am
Your suggestion is interesting, as I have seen the same comment for an Omega watch, and I tried this 5 minutes before your comment has been posted. :)
I must say, the crown runs way smoother with this method.
Also, I let the watch rest for some time just to see If the sound dissapears when it's not fully wound.
Toph
Post by Toph » Mon Feb 17, 2020 11:22 am
It’s funny as I’ve always done that too. The crown catches the threading easier .. and voila
Cheers
Where no counsel is the people fall but in a multitude of counsellors there is safety
Instagram @tophstewart
CW-watches: 29
Post by Bahnstormer_vRS » Mon Feb 17, 2020 12:08 pm
Amor Vincit Omnia wrote:I'm pretty sure Paul is right, but I'd suggest one thing...
Absolutely correct, but there is another step before doing this, which I picked up from the Owners Handbook of my Breguet XX, which is;-
Having (presumably) wound the watch/crown clockwise, to then wind the crown anti-clockwise two or three full turns. This ensures the crown is disengaged from the winding gears.
Then, proceed as per @AVO's instructions above.
C4|C4&W7 BBMF|C5 BOB LE|C6|C7 MkI 47AD|C7 MkII Harrier|C8 MkI|C8 Reg MkII
C8 M2.04 LE|C8 UTC|C9 FLE|C9 Me109 SPC LE|C20 FLE|C40 Speedhawk|C60 K'fisher|C60 FLE x2
C60 Apex|C60 Chrono P'type|C65 Khaki|C65 S'hurst|C65 GMT|C70 x3|C90 PR|C600|C1000
Ian Mc
Post by Ian Mc » Mon Feb 17, 2020 2:54 pm
This is an accepted method of engaging fine threads where it would be very easy to cause damage by incorrect engagement.. Cross threading.
People who regularly work on items requiring reliable thread engagement do this as a matter of routine.
Vintage Omega, Seamaster AT, Seamaster Pro 300, Speedmaster Racing, Speedmaster Moonwatch, Scuro diver, Bering solar, 3x homemade bronze jobbies.C60 bronze, Victorinox INOX.
tikkathree
Post by tikkathree » Tue Feb 18, 2020 6:38 am
Thinks: is there opportunity to participate in this discourse by members of The Honorable Society for Fine Thread Settling or am I too late?
Case backs, gentlemen, case backs.
Oh yes and those naughty Vostoks with their Wobbly Crowns.
QED!
C60 MKI COSC black, C60 MKII Day Date LE white, C6 Kingfisher black, C60 Kingfisher, C600 Tritech x 3, C65 Anthropocene
ondris
Post by ondris » Tue Feb 18, 2020 8:39 am
I don't know if It has something to do with the "screwing down trick" (giving a few anti clockwise turns before going clockwise), but since yesterday the crown runs really smooth.
Might also be the fact that the watch was fully wound ?
I assume there is a system preventing the over wounding?
Post by Amor Vincit Omnia » Tue Feb 18, 2020 8:46 am
It’s an automatic, so there is a clutch that prevents over winding. If you are wearing it consistently you shouldn’t really need to keep winding it as your activity over a few hours will normally be sufficient to power it up. Then you would only need to undo the crown to adjust the time. The screwing down of the crown should not be dependent on the state of wind of the watch, since pushing the crown in towards the case will disengage the winding mechanism.
Ian Mc
Post by Ian Mc » Tue Feb 18, 2020 12:18 pm
QED!
Scew down case backs.....
I would recommend turning anti clockwise to engage the threads before tightening these as well.
The thread pitch is fine.. (Pitch is the distance between two peaks on a thread), so, combined with a larger diameter it is easier to get the back misaligned with the thread and subsequent risk of crossthreading.
Laird
CW-watches: 22
Post by Laird » Tue Feb 18, 2020 3:38 pm
The worst culprits are old Pocket Watch case backs but more often the bezel - which needs removing/replacing every time you want to adjust an RailRoad style safety-featured Lever access rather than the usual Pull out of the Crown !
|C70s-most|C7 BlueBird|C7 IRR COSC|C7 BRG|C7 Mk2 COSC|C7 COSC Valjoux|C3 Blue GT |C4 Phoenix|C5 BoB|C8 Pilots|C60 316L Yellow & Blue|C8 UTC|C60 GMT|C60 Valjoux|C65 Classic & Pepsi|C50 D/D COSC|C1 WT|C9 Pulser & AMGT|C11 Makaira 500 Orange|
heffergm
Post by heffergm » Mon Feb 24, 2020 8:36 pm
I just got a 38mm C60 to compare with an existing 40mm. I immediately noticed the 38mm is doing what the OP described, the 40mm isn't and never did. It isn't anything cross threaded, it feels almost like you're winding the watch as you screw the crown in, like it's acting against a spring. Spinning it anti clockwise before you start to screw it down doesn't have any effect. In fact, it's exactly like adjusting the air screw on a Keihin carburetor... which is basically just that, a screw, backed by a spring. Why it's noticeable on the 38 and not the 40, or whether it's normal I haven't a clue.
Did you ever get a response from CW about this? Also, what size case is your C60?
b_form
Post by b_form » Tue Feb 25, 2020 6:37 am
^ interested in this as well.
I've got the same problem as what OP described (an uneven spring-like clicking when screwing in the crown) on my 40mm Trident 600. The "rotate the other way" doesn't work for me, and I'm sure it's not the misaligned threads.
