Newb question winding the watch
Yesyesnono
Post by Yesyesnono »
Hello all
Just a quick one, it’s advised not to change the date during certain hours ie when the time is between 8pm and 3am however if the watch has stopped how on earth do you know or am I being stupid
Thanks in advance
Re: Newb question winding the watch
Not a stupid question at all.
First of all, you need to know whether it is a.m. or p.m. on your watch. The easiest way is to wind it through 12 o’clock. If the date changes you were on p.m.
Here is the standard procedure that most of us use:
1. Adjust the time to 6 o’clock (doesn’t matter whether its a.m or p.m.)
2. If you need to use the quick change date facility, advance the date to YESTERDAY.
3. Finally, wind the hands on to the date change at midnight. Then continue advancing the hands, remembering that if it is 3 o’clock in the afternoon, say, you will need to advance them by 15 hours.
4. If you’ve done all that your watch should be set up correctly.
Yesyesnono
Amor Vincit Omnia wrote:
Sun Jan 12, 2020 2:34 pm
Superb thank you so much
Yesyesnono
On the same theme how do You know when a Christopher ward is fully wound can you hear it making small clicks
You can hear the small clicks on the C5 that I have but not on my other CW automatic, the C60 GMT. The latter is the watch that tends to go on holidays with me so I wear it all day every day and leave it on the bedside table at night. It stays wound, obviously.
