adjusting milanese strap
grimeymac
Post by grimeymac » Fri Nov 08, 2019 12:51 pm
New Moonglow today (nice) -- is there an official set of instructions (video?) on how to adjust the Milanese strap - so I don't just poke around with sharp pointing things and scratch it!?
Re: adjusting milanese strap
Post by It'sAliveJim » Fri Nov 08, 2019 4:44 pm
grimeymac
Post by grimeymac » Fri Nov 08, 2019 5:15 pm
Seems not. They all seem to refer to a different kind than the one used by CW - this has links that need removing I think, by the look of it. As I said, I can hack around but thought CW might have a how-to guide or reference.
Post by downer » Fri Nov 08, 2019 5:54 pm
I'm fairly sure the CW mesh is produced by Staib - if that helps.
If it is type with links attached to the clasp (for adjustment) I guess they work in the same way as standard bracelet links - although I'm not sure if they use push pins or screw-in pins...
Post by nbg » Fri Nov 08, 2019 5:58 pm
^^^^ Yep they are Staib (or certainly were when CW first started using them). Split push pins IIRC, with an arrow indicating the direction to push in.
Devarika Woulf
Post by Devarika Woulf » Fri Nov 08, 2019 6:10 pm
Ohhhhh a Moonglow! I'm becoming obsessed with this one and it'll be my next CW! Post pictures if you get a chance. :wave:
-Joseph
Post by It'sAliveJim » Fri Nov 08, 2019 10:06 pm
Apologies, I see it is detachable links either side of the clasp and not a flip clasp/move up and down milanese :oops:
Interestingly, A Blog to Watch mentioned that even with all the links removed, it was still too big for his 6.5" wrist :?
