COSC Regulation of a Movement?
Jcalder68
Post by Jcalder68 » Thu Oct 24, 2019 4:08 pm
This is a hypothetical question, but might become reality.
I’d like to add a COSC certified (dive) watch to my collection. Accuracy is always important to me and I quite like the idea of the little certificate too. The issue is size of watch; ideally I’d like it to be the smaller case size that CW do, and in a perfect world it would be my 38mm Vintage C60 Trident 600.
Now, CW will be launching their new military range with COSC movements, and I understand these to be fettled (and certificated) versions of their Sellita movements, the same as the basic one in my C60. From this I am assuming that getting a basic SW movement to COSC specification is possible.
So, my options?
Option 1 would be to politely ask CW if they could replace the basic movement in my C60 with a COSC one. I asked them that very question earlier today, but the best they could offer was a regulation of the existing movement (estimated to be to +/-10sec a day) but they would not entertain the idea of a movement swap or replacement.
Option 2 could be to send my watch off to an independent workshop to get it fettled and certified. I have no idea of who might be able to do a one-off like this, or the costs involved. Any suggestions?
Option 3 could be to buy myself a certificated movement and then ask either CW or my local watch repairer to install it for me. Again, I have no idea of where such a movement can be bought, or if it is even possible to buy such a thing? Again, any suggestions?
Many thanks,
CW Watches (To Date): Trident M3 40mm, C60 Pro 300, C60 Pro 600 Vintage, C65 GMT, C65 Diver Auto, C65 Diver Manual
Others (To Date): Sinn 104, Seiko SNA411, G-Shock
Markornot
Re: COSC Regulation of a Movement?
Post by Markornot » Thu Oct 24, 2019 4:19 pm
You might want to have it professionally "timed"...you may find it falls within COSC specs as it stands. Some do. Unless the certificate itself is important to you, over a period of time, any certified movement may fall out of spec anyway.
Commisar
Post by Commisar » Thu Oct 24, 2019 4:27 pm
Where I am on the USA, North Texas, a few local watch repair places can get things to within COSC specs are very close for about $140 USD and 2-3 weeks of time. However, they won't be officially certified.
neilj568
Post by neilj568 » Thu Oct 24, 2019 4:56 pm
CW will not install a third party movement but it could be possible to get a watchmaker to get the basic movement to approaching COSC tolerances albeit without the certificate but which would obviously invalidate any CW warranty....!!!
Wrist Size 210mm/8.2"
CW-watches: 29
Post by Bahnstormer_vRS » Thu Oct 24, 2019 5:14 pm
Many thanks,
Option 2 is not realistic on the basis that, should you be able to find an Independent Watchmaker to 'get it fettled', it will then be cost prohibitive to have the watch sent off to Switzerland to get a COSC certificate.
In the past, I bought a COSC rated watch from CW at a Nearly New price for the singular reason that the COSC Certificate had gone missing (and it was not cost effective to get a replacement).
This maybe a heretical and sacrilegious suggestion but, if as it would appear on first glance, CW do not (currently) have a watch that meets your desires; have you considered buying an alternative brand watch?
PS > I know its a whisker bigger than your ideal but what's wrong with the C65 Dartmouth?
C4|C4&W7 BBMF|C5 BOB LE|C6|C7 MkI 47AD|C7 MkII Harrier|C8 MkI|C8 Reg MkII
C8 M2.04 LE|C8 UTC|C9 FLE|C9 Me109 SPC LE|C20 FLE|C40 Speedhawk|C60 K'fisher|C60 FLE x2
C60 Apex|C60 Chrono P'type|C65 Khaki|C65 S'hurst|C65 GMT|C70 x3|C90 PR|C600|C1000
welshlad
CW-watches: 9
Post by welshlad » Thu Oct 24, 2019 5:41 pm
On Sellita and ETA movements, "COSC" spec doesn't just mean that the timekeeping is more accurate. Their COSC movements are also always their "Top" grade movements, i.e. with better components. So you are paying for both better accuracy and better components, compared to a basic movement.
So, for Option 1, even if CW were to entertain a movement swap, you would need to pay a premium for the better quality movement.
Option 2 - you should be able to get any standard Sellita or ETA movement regulated to within COSC specs. An independent watchmaker could do that, no problem. But they can't provide a COSC certitificate. Only the COSC organisation in Switzerland can do that. And the movement would need to be removed from the watch to do so - as they only test movements not watches.
Option 3 - you could do this with an independent watchmaker, but CW wouldn't entertain it and you'd clearly invalidate your warranty.
My question is: why do you want to do this? If it's for greater accuracy then get an independent watchmaker to simply regulate your watch - it's the cheapest option and you keep your warranty intact. If it's for a better quality movement, then I think you really need to buy a watch with a COSC-certified movement in the first place.
CWL C60 Mk2 x2 | C65 SH21 | C70 x4 | C8 | C15
Citizen Promaster Tissot V8 Vratislavia S6 Luch 1Hand
Jcalder68
Post by Jcalder68 » Thu Oct 24, 2019 6:29 pm
Thanks for the detailed and informative responses, everyone.
Ok, so my reasons for doing this? Just “because” and “can I” really. I greatly respect the time, skill and effort getting a movement regulated to COSC and I would love the feeling in the back of my mind that the item I have on my wrist has had that craftsmanship applied to it. It’s not just ticking a box in my horological journey, but I know I would get an extra buzz out of knowing that my “regular” C60 is potentially more accurate than any other one out there. I like something unique and different :-)
So, Option 2 is not really a possibility. That was my thinking too.
Option 1 will set me back a staggering £30 for CW to regulate it, so might be the best value for money.
I might find a happy medium (not Russel Grant) and try to source myself a TopGrade Sellita movement and then tap my friendly watchmaker on the shoulder to fit and regulate it.
Thanks again,
PS, The Dartmouth is a cracker, but I’d just prefer the matte ceramic bezel and overall size of my C60.
