Crackle When Screwing Down Crown
kpc001
Post by kpc001 »
I've had this happen some watches, and I thought I'd ask this knowledgeable group. I have a C60 Trident Elite with a Sellita SW200. When I screw the crown down, I hear a little "crackling" when I turn the crown and it closes. Nothing major, but it's not silent. I'm not worried about it, watch works just fine, winds with no issues. Is this something that occurs with the Sellita or some automatic movements? I hope the responses aren't "man, you are so screwed."
Just curious.
Thanks,
-Kevin
-Kevin
C900 World Timer
Trident Elite
C60 Trident Vintage (2nd Gen)
Markornot
Re: Crackle When Screwing Down Crown
Post by Markornot »
kpc001 wrote:
Fri Sep 27, 2019 1:30 am
Do you also “feel” the “crackle”? If so, I suspect it is actually just a slight mis-match of the thread pitch of the crown and case or perhaps some burring in the threads from sub-optimum finishing. I have a few that are like that to some degree and never had any issues and don’t give it much thought. As in life, some screws are less soft and tender than others. :wink:
watchaholic
Post by watchaholic »
^^^Would tend to agree with the slight burring of the threads. Something I have done in the past, and there may be some here who will disagree, but you can, while pressing inward, turn the crown in reverse and feel for the spot where the crown drops into the threads cut into the case. Now turn the crown in the opposite direction as you normally would. This should help prevent any chance of crossthreading.
Dwight
^^^^ I have always done this and never had any difficulty with screw down crowns.
CW-watches: 24
Likewise, on any screw thread; even the lid on my coffee jar.
DavecUK
Post by DavecUK »
You can sometimes get crap caught in the threads....this can make a small noise. When I was a young I often used to see people adjusting their watches at the beach, crown pulled out, or unscrewed!
Before the crown is unscrewed etc.. you should always make sure the area where the stem will be exposed is clean, that you are in a clean place, not outside, no grit on the wind or around dusty gritty environments. When the crown is out, check that there is no crap revealed caught there (remove it if you can). After a trip by the sea/beach be especially careful there is nothing retained on the watch/crown case junction.
watchaholic wrote:
Fri Sep 27, 2019 4:35 am
I got this advice some time ago and have done this ever since, I think it's something everyone should follow.
C60 FLE Scooter Blue, C65 Ombre COSC LE, W11 Amelia (wife)
kpc001
Post by kpc001 »
Great responses. Thanks to all for taking the time to share their experiences. I'll try turning the crown in reverse - something we've all done, just on a very small scale.
-Kevin
C900 World Timer
Trident Elite
FloridaPhil
Post by FloridaPhil »
A couple of mine do that. I was told by CW that it is just a retention clip. Hasn't affected the operation of the watch at all.
WatchChat on Facebook - A relaxed and laid back group of watch enthusiasts chatting about watches and whatever else happens to come up.
