Advice please - Hr hand sits mid between numerals
Beam
Post by Beam »
Hi all
Not been on forum for a while, err looks like years
However I have a 2009 CW forum watch, which for reasons don't know has issue with the Hour hand
At example 7am the minute hand at 12 noon, the hour hand sits between 6 and 7
Just happened
I guess maybe when been setting time, perhaps didn't take the stem out enough or something
Looking for how to correct, without having preferably to get it repaired by a watch maker
Appreciate any help
Beam
Re: Advice please - Hr hand sits mid between numerals
Post by Beam »
PS I would add a picture . Can anyone help on how I do that... cheers
CW-watches: 24
Beam wrote:PS I would add a picture . Can anyone help on how I do that... cheers
How to......
Second FAQ down.
Welcome back, hope you stick around, have some fun and get your watch sorted.
DavecUK
Post by DavecUK »
Time to send it to a watch maker, the hour hand could be loose on it's stem, or there is a different problem with the keyless works if the watch works otherwise normally. When you pull the crown all the way out for hand setting a different set of gears engage the minute wheel and rather than wind the watch you can move the hands directly. Usually this would be evident in the minute hand also not moving well. So hopefully it just needs a little nipping up on the post the hour hand sits on. You would do well to have it serviced at the same time.
I can't imagine the cost of fixing this would add much, if anything to the service cost...probably £120 or perhaps a bit less for the complete service.
Beam
Post by Beam »
I hope this works. Picture of my 2009 Forum watch
DavecUK
Post by DavecUK »
Nice looking watch....
Beam
Post by Beam »
If can for the hr hand.
I was sort of hoping I had done something, perhaps not pulled the crown out enough and could just reverse that
Looks like could be best to get to a watch repairer. It’s 10 years old so maybe due a service
MarkingTime
Post by MarkingTime »
The advice for a service is sound, particularly given the age and that you have a visible fault with the watch.
You clearly cherish the watch, so give it some love. :)
Bungle-ator
Post by Bungle-ator »
Beam wrote:
Thu Sep 19, 2019 7:45 pm
It'll come back to you with the 12 hour marker moved to 2.5 minutes so that it lines up.
DavecUK
Post by DavecUK »
Bungle-ator wrote:
Thu Sep 19, 2019 11:33 pm
not if he sends it to an independent ;)
watchaholic
Post by watchaholic »
I am not a watchmaker, but don't see how this could have happened while setting it. But I do concur, the watch is 10 years old, and by anyone's standards, due for a service. The hands are friction fit on the center stem so a possible knock could have caused this. No matter they will be removed as part of a routine service and any competent watchmaker should be able to correct it. Good luck and keep us posted.
Dwight
miket-nyc
Post by miket-nyc »
This happened recently to the GMT hand on my Christopher Ward C60 Trident Pro GMT. It was still under the guarantee so I returned it to CW, who repaired it.
I think the only possible way this could happen is by a hand coming loose or moving from a shock. A watchmaker should be able to take the movement out and move the hand back for a reasonable price.
gatehealing
CW-watches: 9
Post by gatehealing »
I’d go to a reputable local shop. Too many problems with CW right now to trust that you won’t get a blueberry pie returned instead of your watch. Or they’ll package it such that it bangs around inside the clamshell.
Beam
Post by Beam »
Thanks for suggestions - There is a local guy who has looked at stuff for me in the past - Ill get along there soon. I suspect the note about shock probably correct. Though don't remember doing it - I do Archery and may have had watch on (Though normally remove)
