Is my C600 full of moon dust?
tikkathree
Post by tikkathree » Fri Aug 30, 2019 5:21 pm
So I had the back off the C600 and found something on the inside: cocoa powder? Rust? Unobtainium? It was dry rather than wet and the movement looks very clean: any thoughts?ImageImage
Sent from my SM-N950F using Tapatalk
C60 MKI COSC, C60 MKII Day Date LE, C6 Kingfisher, C60 Kingfisher, C600 Tritech x 3
Re: Is my C600 full of moon dust?
Post by Thermexman » Fri Aug 30, 2019 8:09 pm
Looks like a service is long overdue!
MarkingTime
Post by MarkingTime » Fri Aug 30, 2019 8:16 pm
Looks to me like corrosion particles that have dropped out of the rotor bearing.
Edit: That corrosion being rust.
Post by Amor Vincit Omnia » Fri Aug 30, 2019 8:23 pm
Indeed. Do you know the service history of the watch?
If not, it has probably spent quite a bit of time in Hungary or Spain and ingested a lot of paprika.
DavecUK
Post by DavecUK » Fri Aug 30, 2019 8:25 pm
How old is the watch...looks like dried up lubricant on a movement that has not been serviced in 10 years. Definitely in need to a strip down, clean lubricate and any bad parts changed. I would assume it's running a bit slow now?
As it's a standard movement you should be able to get it serviced at a local watch maker if it's important to keep prices down.
P.S. There is a lot of it, so hopefully it's not the end result of water ingress.
tikkathree
Post by tikkathree » Fri Sep 06, 2019 6:46 am
Nope, no known service history. Recent EBay impulse purchase sans box and papers.
And the fact that it has power reserve to spec and keeps good time does not mean it doesn't need service so yes, service required.
tikkathree
Post by tikkathree » Fri Sep 06, 2019 6:49 am
DavecUK wrote:How old is the watch...looks like dried up lubricant on a movement that has not been serviced in 10 years. Definitely in need to a strip down, clean lubricate and any bad parts changed. I would assume it's running a bit slow now?
It's not running noticeably slow and there's no visual evidence of water ingress but I'd agree that it probably hasn't been serviced.
rarebritishartglass
Post by rarebritishartglass » Fri Sep 06, 2019 7:50 pm
Possibly dried moon glow, probably rust, surely not maintained correctly.
Gasman
Post by Gasman » Tue Sep 10, 2019 6:31 pm
I’d get a full service by a reputable watch maker. Simon Freese is good and reasonable too.
