Mystery of website watches all showing same times?
Craig64
Post by Craig64 » Fri Aug 02, 2019 6:35 pm
Has anyone ever noticed how the product image photos on their website for a particular range all display the exact same time?
If so, how is that possible to achieve in the real world?
Considering the Trident C60 Pro 600 Range: All models currently show the time of 8 minutes past 10 and 34 seconds.
The crowns are fully screwed in, so the movements will presumably be moving as the watch is handled and put into rest positions for photos to be taken.
So what tricks are used to have them all showing the same time down to the second? Or are the images heavily photo shopped from one single initial photo etc?
Forgive me if this sounds a bit of a silly question :?
Regards
Craig
Re: Mystery of website watches all showing same times?
Post by Amor Vincit Omnia » Fri Aug 02, 2019 6:40 pm
No idea, but I guess you could do it with a photo burst over several seconds.
Post by downer » Fri Aug 02, 2019 6:41 pm
It goes deeper... Find me an official modern Omega advert/picture where the date is not set to "8" and I'll send you a prize. :D
(Edited to make the small print more obvious).
Post by Korkki » Fri Aug 02, 2019 6:44 pm
I will PM my address for the prize :)
Post by downer » Fri Aug 02, 2019 7:04 pm
Very good, Kari. However, you appear to have overlooked the small print. :)
Craig64
Post by Craig64 » Fri Aug 02, 2019 7:06 pm
For me that scores a 10 out of 10!
:clap: :clap: :clap: :clap: :clap:
Regards
Craig
addi564
Post by addi564 » Fri Aug 02, 2019 7:12 pm
Does this count.
Sent from my SM-G950F using Tapatalk
C60 Trident 38mm on rubber and GMT on bracelet
C6 Kingfisher black dial on rubber and white dial on bracelet
C5 FLE and C3 FLE
C65 Vintage on bracelet
Tag Heuer F1 Calibre 5
Breitling Superocean 42
srs1286
Post by srs1286 » Fri Aug 02, 2019 7:16 pm
In CW's lineup, you'll notice that the forward facing shots are all positioned exactly the same as they are photoshopped / computer generated. If you look at the actual press shots (the wrist shots, etc.) you'll see some variances.
Feel like I can speak to this as most of the photoshopping I do on the CW's match, line up, angle the exact same. For instance if I pull the red 600m text off of the blue C60, it will be the exact same size, angle and position as the black dial C60. I'm led to believe the front view of the watch laying on its side generally follows the same rule.
Scott
Post by downer » Fri Aug 02, 2019 7:17 pm
Errm.... :lol:
Is it an official Omega picture?
Craig64
Post by Craig64 » Fri Aug 02, 2019 7:27 pm
That makes a lot of sense, and I think you have solved my mystery, thank you very much. :thumbup:
Regards
Craig
addi564
Post by addi564 » Fri Aug 02, 2019 7:31 pm
Errm.... Image
I believe so, got it from their official facebook page
https://www.facebook.com/90884717210/po ... 014657211/
C5 FLE and C3 FLE
Post by nbg » Fri Aug 02, 2019 7:36 pm
Or a non chronograph, non annual calendar Rolex that doesn’t indicate 10:10:31 on the 28th.
They even stick to that for models at events.
Post by downer » Fri Aug 02, 2019 7:46 pm
Errm.... Image
I'd argue that's a "casual" picture, so it can't count. :lol: I think Neil has made my point though. :D
Bounce
Post by Bounce » Fri Aug 02, 2019 9:05 pm
I was told a number of years ago by a watchmaker, that the likes of Rolex , Omega etc use fake non working movements for pictures so that the hands can be set to wherever they want.
Rolex Submariner date.
Tudor Pepsi GMT.
Tag Heuer Aquaracer 500m Auto
Seiko Kinetic Diver
C60 Trident Vintage.
cincfleet
Post by cincfleet » Fri Aug 02, 2019 9:13 pm
I'm led to understand that 10 past 10 for the hands is used as it shows off the whole watch face better. I doubt the watches used for advertising have movements inside hence the crown seated.
