Changing battery
Adie
Changing battery
Post by Adie » Sat Jul 06, 2019 9:04 pm
Hi
So the time has come and I need a new battery .
I've removed the back but my set of cheap screwdriver tools are not small enough to remove the battery cover . lol
What size screwdriver head do I need
Rapid MK2
Thanks
CW-watches: 146
Re: Changing battery
Post by Kip » Sat Jul 06, 2019 10:33 pm
Usually a .80 or .60 blade will do the trick.
PaulJS
Post by PaulJS » Sun Jul 07, 2019 11:42 am
If the Rapide Mkii has the same arrangements as the C4 be careful not to launch the little gold clip into orbit when you release the screw - the spring under the battery is strong enough to do this, as I found out recently!
Cheers,
Paul
Trident Pro White / Blue
C20
C4
Omega Speedmaster II LE
Trident Pro Black/Blue
C70 VW4
C65 LE
C7 MK 1
Scurfa Diver One
