When was the last time you used your timer on your wrist trinket
Ian Mc
Post by Ian Mc » Sun Jun 30, 2019 8:01 pm
For me it today, using my moon watch to time the required engine burn duration on...
The bottom oven cooking pizza!
It came out just right!
Vintage Omega, Seamaster AT, Seamaster Pro 300, Speedmaster Racing, Speedmaster Moonwatch, Scuro diver, Bering solar, 3x homemade bronze jobbies.C60 bronze, Victorinox INOX.
smegwina
Re: When was the last time you used your timer on your wrist trinket
Post by smegwina » Sun Jun 30, 2019 8:33 pm
Flying VFR legs, it gets used all the time, particularly as a backup to the main flight timer.
Sailing, I use the regatta timer.
I also use the bezels on a diver to time meter times for car parking.
Other than that......
Sent from my Redmi Note 6 Pro using Tapatalk
Ian Mc
Post by Ian Mc » Sun Jun 30, 2019 9:05 pm
Flying VFR legs,
Excuse my ignorance, I guess this is a technical term in flight plans or something?
Post by StrapMeister » Sun Jun 30, 2019 9:38 pm
There are two sets of rules for flying any aircraft: VFR and IFR.
  • VFR stands for Visual Flight Rules
  • IFR means Instrument Flight Rules
Depending on the weather conditions a pilot may opt for one set of rules or the other.
C65 Trident Bronze SH21 LE; C9 FLE.
EVS Blood Bikes https://www.freewheelers.org.uk/
Post by nbg » Sun Jun 30, 2019 9:40 pm
This afternoon, to time how long the tea was brewing.
Ian Mc
Post by Ian Mc » Sun Jun 30, 2019 9:52 pm
Thanks for that.
Every day is a school day!
smegwina
Post by smegwina » Sun Jun 30, 2019 10:01 pm
StrapMeister wrote:There are two sets of rules for flying any aircraft: VFR and IFR.
Thanks for this. Was too busy watching last night's recorded UFC to see the question!!!
smegwina
Post by smegwina » Sun Jun 30, 2019 10:22 pm
Thanks for that.
StrapMeister was spot on.
Very simply, when navigating in Visual Flight Rules you fly a series of legs at a known heading and speed (taking wind speed and direction onto account as you can't fly in a "straight" line) that you have plotted. At the end of each leg, you check using visual reference points that you are in the correct place. You then fly the next leg and so on and so forth!
And now back to the watches! Image
Ian Mc
Post by Ian Mc » Sun Jun 30, 2019 10:25 pm
Thanks for that.
So, what watch do you use, and, given all the variables involved, how accurate can you get in terms of location, timing etc?
Psalty
Post by Psalty » Sun Jun 30, 2019 10:27 pm
I use timers almost daily, and quite often the type of timing needed dictates the watch.
Gregory
smegwina
Post by smegwina » Sun Jun 30, 2019 10:46 pm
Ian Mc wrote:
Ian Mc wrote: Thanks for that.
You can use any watch that is clear and easy to read. I normally use a flight timer for "stopwatch" duty. (One in the panel, and one on the kneeboard) but you also have an ETA for the end of each leg (updated on the fly). When communicating with ATC you check time remaining in the leg, check the watch and give them the ETA based on the two.
Every watch I fly with has a chrono on it just in case, and I do use it every now and then as it is a different set of skills and always good to have just in case the others fail.
VFR nav is pretty accurate, providing the legs are not too long and certainly gets you to where you can see the VRP to start the next leg.
Post by atnits » Sun Jun 30, 2019 10:53 pm
This evening, to time the porridge in the microwave. Exploded after 3.5 minutes. (The porridge, not the watch.)
smegwina
Post by smegwina » Sun Jun 30, 2019 10:58 pm
atnits wrote:This evening, to time the porridge in the microwave. Exploded after 3.5 minutes. (The porridge, not the watch.)
Porridge is a dangerous game to play in the microwave. As is trying to microwave an egg in one of those plastic poacher things.
Lethal.
Ian Mc
Post by Ian Mc » Sun Jun 30, 2019 11:36 pm
Noooooo! Disaster!
KevinB
Post by KevinB » Mon Jul 01, 2019 1:49 am
Last week to know when to change the laundry to the dryer. :D
