C9 Single Pusher timekeeping
Victor88
Post by Victor88 » Sat Jun 29, 2019 10:35 am
Hi all
Woke up this morning to find my C9 had lost 2h 20 minutes. Oddly it was still ticking so not sure what gives. I’d wound it yesterday evening about half full so there should have been enough reserve to continue through the night. The chronograph was not running. Recallibrated it this morning and seems to be ok thus far. Question is if anyone else has experienced anything similar?
Thanks.
Re: C9 Single Pusher timekeeping
Post by Amor Vincit Omnia » Sat Jun 29, 2019 10:41 am
You say it's running OK now?
Check it tomorrow morning and if it has done the same there might be a problem with something sticking around the date changeover. I had that happen with a vintage watch once.
Post by H0rati0 » Sat Jun 29, 2019 10:49 am
Before panicking, are you absolutely sure it was set correctly in the first place? I ask because if the power reserve was nearly exhausted but the watch had continued running it should have gained and I have done the same sort of thing myself eg incorrect setting by 10 minutes and then wondering why my watch was wrong against a radio controlled clock.
Another possibility is that it had actually stopped but when you picked it up that impulse started it again so it would seem as if it had run continuously. I would only trust the watch to run to power reserve after a full wind, unpredictable things happen with isochronism.
I do hope you just had a glitch and the watch itself is fine.
Post by Amor Vincit Omnia » Sat Jun 29, 2019 11:09 am
...I have done the same sort of thing myself eg incorrect setting by 10 minutes and then wondering why my watch was wrong against a radio controlled clock.
Glad I'm not the only one who has Senior Moments. I did that with my C65 Diver the other week.
@Victor88 - keep us updated, mate.
Post by H0rati0 » Sat Jun 29, 2019 11:20 am
It's disturbing, but the alternatives are worse!
Victor88
Post by Victor88 » Sat Jun 29, 2019 1:16 pm
Hi all
Thanks for the quick feedback. Think Horatio’s comment on impulse power may be the answer - will give it a full wind tonight and see where things are tomorrow (no date on a C9 monopusher of course.)
Thanks!
rcherryuk
Post by rcherryuk » Sat Jun 29, 2019 3:44 pm
Be careful not to over wind it, if you wind it fully it will stop after a couple of minutes, only way to fix it, let the stopwatch run for a few minute to release some tension on the mainspring.
Problem acknowledged by JJ himself, and this was his advice.
Rob
Samuel Johnson
Victor88
Post by Victor88 » Sat Jun 29, 2019 9:15 pm
Thanks Rob, will bear that in mind.
CW-watches: 19
Post by MiniMpi » Sat Jun 29, 2019 10:13 pm
rcherryuk wrote:Be careful not to over wind it, if you wind it fully it will stop after a couple of minutes, only way to fix it, let the stopwatch run for a few minute to release some tension on the mainspring.
Great information Rob, I wasn't aware of that.
C9 AM GT LE #001/135, C60 Ombré #001/300, C7 Proto, C11 Elite, C7 Bluebird, C70 Ascari, C7 COSC LE, C65 MK1 LE, C60 316L, C9-JH-MK3, C9-40-5DA, C600-IPB, C8-KVKT-MK2, C60 GMT, C60 SKRS, C60-TI-V2, C8 UTC, C8 Flyer MK2, C65 Trident Diver, Rolex 912 Tank.
