Is this acceptable on a £1250 watch?
Merlz
Post by Merlz »
Hi all
My Trident Elite arrived today and upon opening it I wanted to check the bezel action before doing anything else as I’ve read a few negative comments here. To say I am disappointed is an understatement but I would appreciate your thoughts also. In my opinion too much play and lateral movement. Am I being too fussy or is this deemed acceptable on a £1250 watch.
Regards to all.
https://m.youtube.com/watch?v=eRVMuVP_dYg
neilj568
Re: Is this acceptable on a £1250 watch?
Post by neilj568 »
Ring them up direct and complain rather than via the forum and then return under 60/60 and include feedback about why you are returning it
Wrist Size 210mm/8.2"
McDaWisel
Post by McDaWisel »
Don’t see an issue with that - as long as it can be lined up perfectly arrow to 12 and doesn’t move by itself.
In your video the bezel doesn’t seem loose - which is good. There is always a trade off in the “play” and how much force is needed to turn the bezel. The more force is needed the less play it seems to have. But it also becomes more difficult to adjust precisely and you start skipping clicks because you need too much force to turn the bezel...
Either way that looks same as mine. So it’s probably the way it’s designed to be and can’t be repaired or replaced...
Post by jtc »
It might be within tolerance, but if you're not happy then just return it for free.
Sales Corner Feedback
CW | Tudor | Tag Heuer | Omega | Halios | Oris | Seiko | Casio
McDaWisel
Post by McDaWisel »
jtc wrote:It might be within tolerance, but if you're not happy then just return it for free.
Yeah that’s true. I don’t think there is anything wrong with it, but if you are not happy, that’s what the 60 day returns policy is for.
tomc1944
Post by tomc1944 »
Looks perfectly fine to me. There has to be so play in it so that it can move.
C60 Trident GMT MKIII, C60 Trident MKII, C65 Vintage Diver, Oris Williams Chronograph, Oris Big Crown Bronze Brown Dial, Tudor 1926 white 41MM.
Post by TigerChris »
jtc wrote:
Thu Jun 27, 2019 8:53 am
Ahhhh, that magic word again - tolerance :lol: :lol: :lol:
Now, being serious, looking at the video I can't honestly see anything wrong there.
McDaWisel
Post by McDaWisel »
FYI, here a video of my Elite as well as a Sinn that costs double the price. I think that's the way they are designed to operate. Sinn has as much if not even more play...
https://imgur.com/KdAkYVf
Merlz
Post by Merlz »
Thanks for your comments all.
It was more the lateral movement I was disappointed in really but wasn't expecting as much play in the bezel if I am honest. I wanted some comparisons as my Mk 2 Trident has no play whatsoever so I was expecting the same on the Elite.
Thanks again...still undecided.
Post by what-time-is-it »
In my experience if you have doubts on the day of delivery they will linger and tarnish the purchase in the long term if you keep it.
Current collection incl Alpina, Breitling, Bulova, Casio, Citizen, Eterna, Oris, Rado, Raymond Weil, Rolex, Seiko, Tag, Timex, Tudor & Victorinox.
Blackdog
Post by Blackdog »
Merlz wrote:
Thu Jun 27, 2019 12:42 pm
My experience with the MK3 is with a 38mm, so it may not be completely relevant. But I do not see any lateral play on mine. Rotational play it does have some. Don't remember it being quite so much as the one you show, though.
My MK2 has virtually no rotational play in comparison, but it is much stiffer to rotate. Not sure if the design is the same.
Bottom line, if it is not acceptable TO YOU, then that's the end of the story.
I just checked my mk2 Trident and no play, but as Blackdog says, quite stiff. My Seiko Prospex workaday diver also has no play but is even stiffer. I don't think I'd be happy either with the amount of play you are seeing, but maybe there is some tradeoff against stiffness. Any chance of a showroom visit to compare other mk3s side by side?
srs1286
Post by srs1286 »
That is how mine was, wasn't too pleased with it. Curious what the serial number is on that one?
Scott
welshlad
Post by welshlad »
It looks ok to me, but if you're not happy then send it back for a replacement under the 60 day guarantee.
CWL C3 Mk1 | C60 Mk2 x2 | C65 SH21 | C70 x4 | C8 | C15
Citizen Promaster Tissot V8 Vratislavia S6 Luch 1Hand
McDaWisel
Post by McDaWisel »
Don’t think a replacement will do it as several people have confirmed theirs are the same. I think it’s the way they are designed to be.
You can return for a refund, but replacement would probably be the same...
