Uploading photos
Rob s
Uploading photos
Post by Rob s »
im struggling to upload pics. Getting the below message - can anyone help?
ERROR
It was not possible to determine the dimensions of the image. Please verify that the URL you entered is correct.
Paul Drawmer
Re: Uploading photos
Post by Paul Drawmer »
Where in the process are you getting this?
Are you using the full editor box, and the 'attachments' tab and the 'add files' , 'Place inline' buttons? Or some other method?
Rob s
Post by Rob s »
Im using the full editor - add attachments - selecting the JPEG file which is saved on my hardrive. It the loads (green bar on the attachment status column) then the bar turns to a yellow triangle (attachment failed) and if i click on the triangle thats the error message that comes up.
Im wondering if there is a file size limit maybe?
Could be. I don’t think the forum software compresses images like Imgur &c. do.
If you have Photoshop try a simple edit and save the edited image as a lower resolution file. Might work.
Rob s
Post by Rob s »
Thanks for the replies guys. Ive just reduced one of the images down to a smaller file size and its worked so I think its must have been that. Need to resize the rest.
CW-watches: 25
I had the same issue a few days ago when I was trying to upload a photo from my laptop's desktop screen; although routinely I use Tapatalk to upload and host my photos.
No apparent reason for the failure, and photo file size was not large. I think I just cancelled, tried again and it was OK.
To the best of my knowledge there is no file size limitations for photo size upload (within reason) in the forum software.
Tapatalk seems to have a 3MB limit.
Rob s
Post by Rob s »
Bahnstormer_vRS wrote:I had the same issue...
The files were just over 5mb each, I reduced the size and they all worked. Maybe a 5mb limit.
Sent from my G8441 using Tapatalk
