Losing time
watchaholic
Losing time
Post by watchaholic »
Quick question, can being magnetized cause a watch to run slow? I was always under the impression that magnitizium caused the coils in the balance spring to attract and rub, causing the amplitude to shorten, thus speeding up the watch. I have a demagnetizer and this has been the fix on other watches in the past. Over the last 2-3 days, the SH21 in my C8 has started losing approximately 5 sec over 24 hrs, which might not be sooo bad, but it has never done this since new. In fact if I ever let it run down into the 1 day range and it lost a sec or 2, all I had to do was wind it to 4.5 days and it would, over 24 hrs gain that second back. Very easy to regulate. If kept between 2 and 3.5 days it was always spot on. Don't know what would cause this sudden change. Has not been dropped. Just wound it all the way up to 5. I will check again over the next 24. Wound this tight it should gain.
Dwight
Jcalder68
Re: Losing time
Post by Jcalder68 »
It does seem odd behaviour, have you tried to de-magnetise it this time around?
My (limited) inderstanding is that a sudden change in timekeeping accuracy (gain or loss) is caused by a sudden “trauma” to the mechanism - magnet, drop/impact or water ingress. On the other hand, a slow change of timekeeping is down to slow wear of parts, slow thickening of the oil etc... like you, I have only heard of magnetism causing a sudden gain in timekeeping, normally 30sec a day or more. I therefore doubt your change to +5sec could be magnetism, but the sudden change is curious.
Any change that water has got it? Any exposure to exceptionally high/low temperatures that might have affected it?
watchaholic
Re: Losing time
Thanks for the response. I am in complete agreement with everything you said. Can't think of anything out of the ordinary as far as temperatures, shock, or water. Watch is only 2 years old in Feb, part of a 4 watch rotation, and regularly sits for a week at a time, then worn 3-4 days, so we will rule out service issues. Have not tried the demagnetizer yet, although this watch did start running fast, about 5 months ago, and responded perfectly to the demag. I am not aware of the possibility of harming the piece by using the demag if not necessary, so I will try if all else fails. May try to regulate myself. Been looking for a reason to buy that Lepsi Scope timer. Do you know anything about these? I will update as I learn more.
Dwight
Re: Losing time
Just as a rule of thumb and all things being equal (really!) a watch will typically run faster as it runs down and slower when fully wound, but isochronism is a complex subject.....
watchaholic
Re: Losing time
Check out that wall plug
I do have a pretty decent fluid filled boating compass that showed a slight deflection when the watch was presented, however nothing like previously when the watch took off running fast. Just ran it through the demag and reset so we will see over the next 24 hrs. Picked up this sweet demag on ebay a few months ago for $25. Used it on my Oris and C8 so far. Worked fine. Just a little disappointed I needed it at all.
Love NOS
Dwight
Bident
Re: Losing time
Post by Bident »
watchaholic wrote:
Sun Mar 10, 2019 8:50 pm
I mentioned this before in an older post, so if others are re-reading this, please bear with me. My C65 Trident Diver was magnetized, presumably from X-Rays in customs which I read is not uncommon. I researched the issue and found the following on the JLC website: https://www.jaeger-lecoultre.com/us/en/ ... etism.html
According to JLC, magnestism can slow down timekeeping as well as speed it up, and in fact, can even stop a watch, which is what occurred with my C65. I downloaded the Lepsi app on my iPhone and bought a compass, both confirming the magnetism. I bought a demagnetizer from Amazon (the really expensive one because the cheapo $10 one was dead on arrival and sent back) and I haven't had any problems since. I hope you have the same result.
Bident
Re: Losing time
Post by Bident »
Also, I've read whenever you demagnetize, your watch shouldn't be running. I've never really understood if that meant let it depower from not winding or just pull the crown out to hack, but I've done the latter and everything seems okay.
watchaholic
Re: Losing time
Bident wrote:
Tue Mar 12, 2019 4:59 am
I have never heard that before, guessing it wouldn't hurt to have it stopped. I did not the first time, didn't seem to hurt any thing. But I probably will in
the future. I did read the article on the JLC website. Interesting note on the bottom of my demagnetizer concerning the hair spring. If I had a timer, I would know for sure by now. I did check at the 12 hr mark, and with 3.5 days on the meter it was spot on. Keeping my fingers crossed. Thanks
Dwight
