Swapping a Quartz for an Automatic?
chickumz
Post by chickumz » Mon Jan 07, 2019 4:40 pm
Hello,
I love my Trident 300 however i prefer an automatic movement. I was wondering if the 300 and 600 have the same case, and if so has anyone managed to swap the Ronda movement out for the Sellita SW200-1 or an ETA 2824-2?
Any help or advice would be greatly appreciated.
Lorne
Re: Swapping a Quartz for an Automatic?
Post by Mikkei4 » Mon Jan 07, 2019 5:16 pm
I'm sure this has been discussed before on here but somebody knowledgeable will be able to tell you.
Even if it could be done it'd probably be easier to sell the 300 and buy a 600 from CW or this forum once you have sufficient posts.
smegwina
Post by smegwina » Mon Jan 07, 2019 8:38 pm
If I remember correctly, dial feet are in the wrong place, the case backs are different and you would need to be sure that the date wheels line up.
Sent from my Redmi Note 6 Pro using Tapatalk
Bounce
Post by Bounce » Mon Jan 07, 2019 11:42 pm
Welcome to the Forum, I would sell the 300 & buy a 600 or if you prefer find an old 300 Auto. A lot easier than the open heart surgery it would need. :D
Rolex Submariner date.
Tudor Pepsi GMT.
Tag Heuer Aquaracer 500m Auto
Seiko Kinetic Diver
C60 Trident Vintage.
MarkingTime
Post by MarkingTime » Mon Jan 07, 2019 11:58 pm
As far as I know, the case dimensions are different. Quartz watches are generally thinner and so would not take an automatic movement.
smegwina
Post by smegwina » Tue Jan 08, 2019 12:12 am
MarkingTime wrote:As far as I know, the case dimensions are different. Quartz watches are generally thinner and so would not take an automatic movement.
The thickness difference can be catered for with a deeper case back, but it is a valid point!
MarkingTime
Post by MarkingTime » Tue Jan 08, 2019 12:21 am
If the overall case size difference is simply due to the case back thickness, then it is do-able, I presume.
So swap movement and case back together? The only way to be sure, would be to ask CW, or try it.
Failing that, buy the auto and sell the quartz, no faff involved.
smegwina
Post by smegwina » Tue Jan 08, 2019 9:32 am
MarkingTime wrote:If the overall case size difference is simply due to the case back thickness, then it is do-able, I presume.
Certainly doable, but it's quite a lot of effort. You would also need to find a movement with a dial attached to avoid the issues I mentioned earlier, which then further complicated matters.
Or.... Keep the quartz as a grab and go and get an auto too! Image
Post by TigerChris » Tue Jan 08, 2019 12:11 pm
Definitely the way to go :thumbup:
DerekMc
Post by DerekMc » Wed Jan 09, 2019 6:29 pm
Hi,
It would present a lot of problems, as you would need to get a good movement, a dial and hands as none are interchangable on these watches from my knowledge of the movements.
Never argue with an idiot, they drag you down to their level, then beat you with experience.
Trident Pro 600 Black ceramic old logo
Trident Pro 600 Blue ceramic
C9 Harrison
Tissot x 2
Ebel Sport Classic
chickumz
Post by chickumz » Wed Jan 09, 2019 8:21 pm
Hello,
Thankyou all for the replies, it's much appreciated. I had a suspicion the cases were different between the 300 and 600. I have swapped dials and bezels in my seikos but didn't know if it would be possible here.
I love my 300 so I think the best option, sadly, is to keep it.
(And then buy a 600 🤔😂😂🙈)
theemaadhatter
Post by theemaadhatter » Thu Jan 10, 2019 2:49 am
Though the question is generally answered, I'll put this here in case anyone else come across the thread. Even if they the two movements are the same diameter and height (unlikely on the height), the hand fittings, movement holder, and dial feet will be different. In other words, nope. I mean you could put an automatic movement in it with the right holder and removing/resetting the dial feet, but the hands won't fit, the diameters will be different on the Ronda vs the Sellita/ETA.
TMH (https://watchcomplications.com)
"it is maddening choosing your outfit based on the watch you want to wear..."
CW: C1 Moonphase, C65 Trident Vintage, C3 Chronograph, C7 Rapide Day/Date LE, C8 Power Reserve, C60 Trident Ombré LE
