Panerai
JonesNT
Panerai
Post by JonesNT » Sun Dec 30, 2018 2:30 pm
In terms of styling which CW would most closely resemble the above? Thoughts? Thank you.
CW-watches: 23
Panerai
Post by gaf1958 » Sun Dec 30, 2018 3:00 pm
The C11 range - the MSL and Makaira are the most Panerai like CWs - although they look like they’ve been crossed with a Bell and Ross...
CWL C1+2xC3+4xC6+3xC7+C11+2xC60K+3xC60T+5xC65+C70+C600
Omega Ω 3xSpeedy+5xSeamaster+DeVille+AT+Dynamic
Zenith+Tudor+2xOris65+4xMagrette+18xSeiko+6xVintage
B&R+Farer+Gavox+Hamilton+LumTec+Mido+MkII+2xSteinhart+2xVisitor+more
Family 11xCW+2xΩ
scanny
Re: Panerai
Post by scanny » Sun Dec 30, 2018 4:06 pm
A C11 next to a PAM 000 from an older photo.
I used to enjoy the C11 a lot, it wears fairly small to it avoids being pranged off door frames etc.
PAM’s are magnets for a scratch or ding.
CW-watches: 27
Re: Pannerai
Post by Bahnstormer_vRS » Sun Dec 30, 2018 4:19 pm
scanny wrote:A C11 next to a PAM 000 from an older photo.
Wouldn't the C11 look bigger, and more of a match for the PAM, if it was the steel case version?
To my mind the C11 MSLs are too slim to compare with a Panerai (someone will now tell me you can get slim Panerais), and you need the C11 Makaira, preferably the thickest Extreme version, for the better comparison.
C3 Chrono |C4 | C5A MkI | C5 BOB LE | C6 x 4 | C7 MkII Harrier | C7 Chrono
C8 MkI | C8 Reg'tor MkII LE | C8 Flyer PR | C9 2011 FLE | C9 Me109 SPC | C10 | C11 Extreme
C60 x 4 | C60 Chrono P'type |C65 Diver P'type | C600 | W7 BBMF
Other brands? Maybe
Re: Panerai
Post by Viognier » Sun Dec 30, 2018 5:12 pm
Aligned with Gary that the C11 is much closer to a Bell & Ross than a Panerai......that said as far as CW watches go, agree that the C11 is closest but certainly much different
Re: Panerai
Post by Thegreyman » Sun Dec 30, 2018 8:39 pm
Viognier wrote:Aligned with Gary that the C11 is much closer to a Bell & Ross than a Panerai......that said as far as CW watches go, agree that the C11 is closest but certainly much different
I'd agree the C11 is definitely the closest CW to a Panerai by far. It does resemble the Bell & Ross to an extent in that the C11 is more of a squared case than the Panerai, the C11 hands are also very similar to the B & R which can be seen from @scanny's photo of his collection.
In terms of dimensions the C11 Makaira Pro is near in size to my PAM 510. Although the case diameter is less at 42 vs 44mm, the height of 13.4 vs 14mm and lug to lug of 53.7 vs 53.5mm are almost identical.
Sent from my SM-J320FN using Tapatalk
C11 Makaira Pro, C60 FLE Scooter Blue, C60 Kingfisher LE, W11(wife)
CW-watches: 27
Re: Panerai
Post by Bahnstormer_vRS » Sun Dec 30, 2018 11:16 pm
That's disturbing news Patrick. :?
I think I ought to just concentrate on my Makaira Extreme and be content. :D
Other brands? Maybe
baldrick
Re: Panerai
Post by baldrick » Mon Dec 31, 2018 9:09 am
JonesNT wrote:In terms of styling which CW would most closely resemble the above? Thoughts? Thank you.
OP, I'll refer to the gang on which CW looks most like a Panerai but, if you're generally looking for a cheaper alternative to Panerai thay isn't a straight-up copy, I'd suggest looking at Magrette.
Great quality watches from NZ for a decent price, with PAM cues but enough of their own style.
Sent from my SM-G960F using Tapatalk
Re: Panerai
Post by Thegreyman » Mon Dec 31, 2018 10:19 am
Are you getting tempted to join the Panerai club Guy? :lol:
The relative slimness of my Panerai is for the handwound movement. The autos are quite a bit thicker, the auto I was looking at is 18mm for the 44mm case size.
The other main case size that Panerai do is 47mm and I suspect you may prefer that to the 44mm, knowing that you like a watch with some heft/size.
Re: Panerai
Post by Thegreyman » Mon Dec 31, 2018 10:22 am
I think you're right, the Magrette more resembles the Panerai (certainly in the shape of case) than the C11. There are/have been a few Moana owners on the forum, nice looking watch.
CW-watches: 23
Re: Panerai
Post by gaf1958 » Mon Dec 31, 2018 11:52 am
Thegreyman wrote:The other main case size that Panerai do is 47mm and I suspect you may prefer that to the 44mm, knowing that you like a watch with some heft/size.
I think Guy should go for a nice svelte 11mm thick 42mm Radiomir 512 or 620 with either hand wound or automatic movement respectively. The dressy PAM. :)
Family 11xCW+2xΩ
CW-watches: 27
Re: Panerai
Post by Bahnstormer_vRS » Mon Dec 31, 2018 11:59 am
Nooooooooooo? :shock:
Other brands? Maybe
smegwina
Re: Panerai
Post by smegwina » Mon Dec 31, 2018 2:50 pm
Knackers to that Gary! Image
Guy, be a man and get a 47mm sub. It will be the only watch you need. Image
Sent from my Redmi Note 6 Pro using Tapatalk
CW-watches: 27
Re: Panerai
Post by Bahnstormer_vRS » Mon Dec 31, 2018 3:06 pm
@Smegwina - I take we are talking Submersible not Submariner, Nick, and what about the Deep Sea you advocate I buy? Where does that fit in? :problem:
Other brands? Maybe
Re: Panerai
Post by Thegreyman » Mon Dec 31, 2018 4:10 pm
Guy, you can get a Parnis homage to the Panerai in order to "try before you buy", just as you've done with the DSSD. That way you can decide if you are going for the PAM, the Rolex (or both :D ).
