Time / date adjustment
josbrownlie
Post by josbrownlie » Wed Nov 28, 2018 11:07 pm
Is it just me or does anybody else only adjust the time / date in the normal direction of change i.e. clockwise for the time, and date increasing numerically. I've just been watching a few videos on YouTube and noticed that some of them show time / the hands going backwards (anti clockwise) which horrified me. Am I alone in my time (and date for that matter) adjustment habits?
FS: MSTR MAJOR MJ106TL Gold/Black viewtopic.php?f=46&t=51230
Breitling B-1, CWL C9 Big Day Date x2, C60 Trident 300, C9 Jumping Hour Mk III, C9 Moonphase, C60 Trident Pro 600 x2, Steinhart Ocean 1
Re: Time / date adjustment
Post by Thegreyman » Wed Nov 28, 2018 11:11 pm
Clockwise only
C11 Makaira Pro, C60 FLE Scooter Blue, C60 Kingfisher LE, W11(wife)
Post by Mikkei4 » Wed Nov 28, 2018 11:18 pm
Clockwise only also.
CW-watches: 23
Post by gaf1958 » Wed Nov 28, 2018 11:22 pm
Aye, clockwise only....
CWL C1+2xC3+4xC6+3xC7+C11+2xC60K+3xC60T+5xC65+C70+C600
Omega Ω 3xSpeedy+5xSeamaster+DeVille+AT+Dynamic
Zenith+Tudor+2xOris65+4xMagrette+18xSeiko+6xVintage
B&R+Farer+Gavox+Hamilton+LumTec+Mido+MkII+2xSteinhart+2xVisitor+more
Family 11xCW+2xΩ
CW-watches: 146
Post by Kip » Wed Nov 28, 2018 11:31 pm
The answer I always give to this question...
Kip wrote:
Tue Feb 14, 2017 1:22 pm
Very generally speaking, a time only watch could be set in either direction. A watch with a date should never be set by rotating the hands counterclockwise. Your problem comes with the date mechanism. They are not designed to go in reverse and you risk permanent damage to the date mechanism by doing this.
It is best to always go forward when setting the time. This creates the proper habit in case your watch has a date or other complication that can be damaged by going backwards. A watchmaker is trained to do this to avoid potential problems.
There are some quick set dates that allow back and forward movements to set the date, but these are generally the exception.
For future reference, because many movements require different time frames to set dates, My method works for most movements and eliminates the guesswork.
My method....
How do I set or correct the time and date on my watch? (Always Clockwise)
You should always consult the owners manual for your watch but this method will work for most watches.
1. Set watch to 6:00 (no matter am/pm).
2. Set day/date to day before.
3. Turn hands until proper date appears (am) and then proceed to set proper time am or pm.
josbrownlie
Post by josbrownlie » Wed Nov 28, 2018 11:35 pm
Ah yes the ever problematic issue of adjusting the time when the date change mechanism is engaging.
Also glad to hear I'm not on my own ....
Essex Paul
Post by Essex Paul » Wed Nov 28, 2018 11:47 pm
Clockwise as a matter of habit.
Watches with date, just as Kip said.
Although I don’t set at 6 necessarily.
I adjust date for the day before then wind round clockwise till date clicks over then set time.
:thumbup:
Post by H0rati0 » Thu Nov 29, 2018 12:38 am
Kip's method covers all the bases, ignore at your peril.
smegwina
Post by smegwina » Thu Nov 29, 2018 10:19 am
Depends on the watch/movement
My planet Ocean can be adjusted for both time and date in both directions.
The normal ETAs however I would only adjust clockwise.
Sent from my Redmi Note 6 Pro using Tapatalk
CW-watches: 23
Post by gaf1958 » Thu Nov 29, 2018 10:36 am
smegwina wrote:My planet Ocean can be adjusted for both time and date in both directions.
Is that a calibre with the independent hour hand Nick? Great for travel as well as easy time & date setting.
Family 11xCW+2xΩ
smegwina
Post by smegwina » Thu Nov 29, 2018 10:39 am
It is Gary, the 8500.
It is actually a bloody useful feature.
You must have about 15 of 'em!!!! Image
CW-watches: 23
Post by gaf1958 » Thu Nov 29, 2018 10:41 am
Had mate, had :) I still have a couple of 1538 quartz models that have the same feature though...
Family 11xCW+2xΩ
smegwina
Post by smegwina » Thu Nov 29, 2018 10:47 am
gaf1958 wrote:Had mate, had :) I still have a couple of 1538 quartz models that have the same feature though...
That's true. Actually I think the original quartz c7 had this feature too!
CW-watches: 27
Post by Bahnstormer_vRS » Thu Nov 29, 2018 10:51 am
Yes Nick.
The C7 MkI quartz had an independent hour, although I don't know that it was omnidirectional on adjustment.
C3 Chrono |C4 | C5A MkI | C5 BOB LE | C6 x3 | C7 MkII Harrier | C7 Chrono
C8 MkI | C8 Reg'tor MkII LE | C8 PR & M2.04LE | C9 2011 FLE | C9 Me109 SPC | C11 MakExt
C60 x4 | C60 Chrono 300&P'type |C65 Diver Khaki & P'type | C600 | C1000 | W7 BBMF
