Rubber strap for my C60 with curved ends
- Junior
Hi.
Anyone seen an Rubber strap with curved ends that will fit my C60 trident? Like the one from crafter blue for the seiko
Skickat från min BLA-L29 via Tapatalk
Re: Rubber strap for my C60 with curved ends
Have you got a C60 MkI (300m WR, aluminium bezel) or MkII (600m WR, ceramic bezel except quartz)?
Reason I ask is that CWL used to produce a rubber strap with fitted ends for the C60 MkI, there were two variants, but have not done so for the MkII.
If you're after the MkI strap you'll have to rely upon a pre-owned one turning up sometime.
Hope this helps.
Hope this helps.
- Junior
Mk1 here. Never seen that strap
That strap originated with the C6 Kingfisher and was used with the early Mk1 Tridents. The problem(s) with them are
1) they're a bast**d to fit and;
2) they've all aged and seem to suffer from sudden cracking, so I don't think they're a viable solution - unfortunately...
Maybe something like this not branded omega ofcourse so its about 20$-30$
I'm saying beacause I want to buy it but what if it doesn't fit so if anyone knows I think it should fit
Sent from my Lenovo Vibe P1 using Tapatalk
Unlikely it would fit. It is designed as an alternative to the PO, which has a different case diameter and curve, and probably a different spring bar position.Danchy007 wrote:Maybe something like this not branded omega ofcourse so its about 20$-30$
However...... Being rubber it may "squish" into the right position.
You pays yer money........
I know that's what's bothering mesmegwina wrote:Unlikely it would fit. It is designed as an alternative to the PO, which has a different case diameter and curve, and probably a different spring bar position.Danchy007 wrote:Maybe something like this not branded omega ofcourse so its about 20$-30$
Well I ordered the strap a week ago so I'll update you all when iz arrives
- copemanphoto
Looks like it was made for the C60, nice and tight from the photo.
Cheers, Mike.
Cheers, Mike.
Cheers, Mike.
That's beacause of the angle but it does fit pretty well
- Wintersports
Do you have the link for where you got the strap?
C7 Rapide Mk2,
Tag Aquaracer
Breitling Superocean Chrono
Omega Seamaster Vintage 1947
Panerai on Metta Catharina Strap
Cartier Santos - worn by Mrs
Two Steinharts, Phoibos, Keinzle
Parnis. Heimdallr Willard, Steeldive bronze... all boys' toys
Tag Aquaracer
From OPs other thread https://m.ebay.co.uk/itm/22mm-Rubber-St ... 0890.m2460
Sent from my iPad using Tapatalk
- 674 Views
- 461 Views
Last post by MiniMpi
- 23 Replies
- 2530 Views
- 1121 Views
- 155 Views
Last post by BrandonT
