A number of strap suppliers get mentioned. As I have a Toshi, SteveO and BikerMC strap I though I would do some pictures to show the differences compared to a CWL C8 Pilot and a black alligator on a C40.
Starting at the top is a Toshi, the strap not on a watch is SteveO, the tan is BikerMC, at the bottom is the C40 alligator and at 9 is the C8.
A close up shows that the Toshi is definitely the thickest and the alligator is last.
The profile shows the Toshi, followed by BikerMC, SteveO and the C8.
So if you are looking for thickness Toshi seems to have it based on these samples but they so say the thickness will vary depending on what leather they have in.
The SteveO strap is the softest and most pliable followed by the C8 (and the C80 strap is teh same). The C40 alligator strap varies being soft at the tails but stiffer towards the spring bars. That may be due to the "build up" so that the strap fits the case.
The Toshi and BikerMC straps were the stiffest but they were also the thickest which may explain part of the stiffness.
The SteveO straps gets awards for the most funky packaging. The strap is wrapped in a sheet of bright blue tissue paper, then purple tissue paper. It is then sealed in a plastic bag and the envelope is a silver foil bubble wrap envelope.
SteveO also advises to polish the strap with Natural Dubbing or leather polish.
Different thickness
Re: Different thickness
Interesting comparison Ian, thanks.
Have to admit, I found the Toshi's a bit too thick when I tried a couple.
have to say the Toshi on my Sector is almost as thick as the case is deep!downer wrote:Interesting comparison Ian, thanks.
- Robin CB
Sounds like the Steve-o-strap is your new favourite then
Useful comparison Ian - thanks.
Here are two of my CWs on SteveO strapsRobin CB wrote:Sounds like the Steve-o-strap is your new favourite then
Des
Des
C7 Bluebird, C8, C8 (Quartz), C11 Titanium Extreme 1000, C11 Makaira Pro 500, C60 (Quartz), C60 Sapphire
Various G-Shocks, Kremner Marine, Laco Archen, Precista PRS-17-C, RLT 42 Navigator, Rolex Datejust, Steinhart Ocean 1 Vintage Red, Heuer Monaco.
- Monkey
I went to see 'Mr Toshi' and saw several straps, and they are nicely made, but pretty thick, so think you'd need a reasonable chunky watch and not have skinny wrists like me to carry them off!!
